Old 3-Mar-2011, 11:49 PM   #1
rgallop
Smile Antenna upgrade or booster?
Here is my report:
http://www.tvfool.com/?option=com_wr...c77a1917fa4a69
Antenna: Philips MANT410 (powered rabbit ear type on top of the living room tv)
Converter boxes: Access HD 1080D
I can currently pull in all the KC digital stations with some movement of the UHF antenna. The power button is turned all the way up on the UHF selector. I have split it off to my downstairs computer (Pinnacle PCTV 800e usb) device, from there, the cable goes outside the house, and it's split again leading to the bedroom tv's about 40 or 50 ft away. Cable is newer coax that recently ran comcast, surewest, and uverse over the last 2 years. Anyway, I am getting weak signal/pixelation on the bedroom tv's and once in a while on the living room tv.
I guess my question is should I invest in a booster of some sort, or should I go with an outside antenna and mount it to the back deck or something. Also, am I too far form St. Joseph or Topeka to pull in their stations? They are probably just repeats of the KC channels anyway.
rgallop is offline   Reply With Quote
