Old 2-Mar-2011, 2:48 AM   #7
No, all sources of noise add together... Co-channel interference is continuous and spans the entire spectrum of the broadcast channel, making it more problematic. But random noise from any other source (including amplifiers and receiver front-ends) will contribute to the problem.
If you build in a cushion, you are more likely to be happy with the resulting service... If you build to the bare minimum, expect unreliable reception.
