Old 1-Mar-2011, 4:32 PM   #1
Remo
Northern Neck Va
I recently dropped Direct TV so I'm starting from scratch. I have a 9521 rotor and the antenna will be roof mounted 25 ft. AGL, and the house is 40 ft above sea level. The closest TV stations are 65-80 miles away. I am near the edge of the Ches. Bay so 40 degrees to 180 degrees is a mostly an over water shot. From 300 degrees to about 15 degrees I have a 40 ft hill blocking my northerly shots. The Norfolk stations are at about 180 degrees and the Richmond stations are about at about 250 degrees overland. I do prefer to watch the Va. stations.
I am thinking about buying a Wineguard HD8200U antenna and a Wineguard AP8275 amplifier. Not at all set on that selection and open for suggestions.
Station plat
http://www.tvfool.com/?option=com_wr...c77afc531544cf
To get a better idea of my situation I live near Reedville Va.
Remo is offline   Reply With Quote
