Old 28-Feb-2011, 6:08 PM   #4
FWIW: The FCC says you can place an antenna on your roof... http://www.fcc.gov/mb/facts/otard.html Your HOA will most certainly know this, though I doubt they are willing to be the ones to tell you.
The J-pole used to mount your dish makes an excellent mast for the small and mid-size antennas. When aiming south (generally), an existing J-pole is usually mounted in a convenient spot. The coax from you satellite installation is compatible with OTA reception, though many of the other components will not be.
