Yes, there is hope...
A 'do-it-yourself' size antenna such as the RCA ANT-751 can mount on the side of the house. My preference would be a larger antenna, up high... but the smaller antenna should give you a solid lineup of programing when mounted outside, aimed at about 140° per your compass.
Attic mounting can/will rob you of a surprising amount of signal.
