TV Antennas and Reception
Yes you can add the power inserter after the 50 foot run of coax. Like this , Antenna-> Coax-> Power inserter. If only one Tv is connected then you do not need a splitter. If 2 Tv's are connected then use a 2 way splitter , If 3 Tv's are connected the use a 3 way splitter , If 4 Tv's are connected then use a 4 way splitter , And so forth . Each time a split takes place the signal strength is reduced. Do not use a 8 way splitter for 1 or 2 Tv's.
