Old 26-Feb-2011, 6:27 PM   #40
olimazi
ground wire...
Cable coax comes in, about a foot from the foundation, and hits a ground block - the length of the ground wire from the block to the water pipe is about 1 foot.
the Fios guy did a much cleaner install of the fiber than the Comcast guy did with the coax - yer right, it depends on who you get.
Probably.
It really depends on the length of the ground wire from the ground block to your house ground. If the CATV installer did it right, you'll be safe and legal, but not all CATV installs are done properly.
olimazi is offline   Reply With Quote
