Old 27-Feb-2010, 3:23 PM   #3
Dave Loudin
Hello. mtownsend has given you solid advice. If you have the possibility of an attic install, you might consider a home brew solution documented here. The advantages of this bow-tie array (NOT the youtube design!!!!) are:
relatively broad receive pattern
positive gain at high-VHF (the same as, or better than, a dipole)
ease of construction
Good luck!
