Old 25-Feb-2011, 4:19 PM   #21
Originally Posted by bondo View Post
would it be a possibility to use a channel 13 join-tenna to combine both antennas?
Perhaps the Jointenna would work. If not try a UVSJ.
The Jointenna would allow for reception of PBS when using a 7-69 antenna aimed at 82°. The UVSJ would filter out PBS on channel 9 and a UHF only for 82° would be OK.
If a Jointenna works, that's an ideal solution; but a Jointenna could allow some channel 13 from the 7-69 antenna to creep in, making the multipath worse instead of better.
