Old 24-Feb-2011, 11:42 PM   #20
bondo
I agree with T.G., this is certainly a fight with multipath. If you can not mount any higher, for whatever reason then there is no point researching it... As I looked at it, it appeared that you would get substantially better signal from the stations on Queen Anne, Capitol Hill and West Tiger if you could get above 35' AGL.
I would expect the multipath problems for KCPQ would be less also.
You don't need the gain, but the directivity of an Antennacraft Y10713 makes it my choice for a dedicated CH-13 antenna at your location. (Directivity is a primary antenna quality useful for combating multipath.)
ok thanks. Yeah 35' is probably not doable for me, not with my setup anyways. I'm just using EMC conduit that that I made slide into fence stock a couple feet, and attached to a deck. Feels sturdy at 20' but 35 would be pushing it. I could definitely see the benefit for doing 35 especially for cbs.
bondo is offline   Reply With Quote
