Old 24-Feb-2011, 7:34 PM   #15
Tower Guy
Originally Posted by bondo View Post
If I go the 2 antenna route, and go with a decent VHF directional antenna, what would you suggest I use to combine the UHF pointing at around 66 and the VHF into one cable?
It's not that simple. You have VHF stations arriving from 279° and 73°. Your UHF stations arrive from 66° to 94°.
Therefore you need two VHF antennas and a broad beam UHF antenna with good F/B ratio or a 7-69 antenna aimed at 82° plus a VHF only aimed at 279°. I can't predict which antenna combination would work best with your terrain. I can predict that trying to combine them into a single feed will be hard and/or expensive. That's why the suggestion to use the dual inputs of your HD Homerun, one for each of two antennas aimed in different directions.
