TV Antennas and Reception
If you will like to install a outdoor type of Tv antenna in the attic , providing the roof is not metal has no foil backed insulation or solar panels on the roof. then a simple all channel antenna like a RCA ANT751 or Antennacraft HD850 or Winegard HD7010 or ChannelMaster CM3016 will work fine. And yes you can put the out door Tv antenna on top of the roof. . . No preamplifier is needed for 1 or 2 Tv's connected.
