Old 23-Feb-2011, 12:48 AM   #5
John Candle
TV Antennas and Reception
The television transmissions are Strong. Buy the Philips SDV5119/27 , NON Amplified indoor Tv antenna at Walmart . Take it to the house where you live and where a digital Tv is at , or a analog Tv with a digital to analog converter box , connect the antenna to the digital Tv or the digital to analog converter box , Turn on the Tv and if there is a digital to analog converter box , turn that on also. In the menu of the digital Tv or converter box will be some wording that says something like this--> scan for digital broadcast television channels. May not be those exact words , however the meaning will be the same. If a digital to analog converter box is connected to analog Tv , the out put of the converter box can be switched to channel 3 or 4 for the analog Tv to receive. At your location switch the converter box out put to channel 3 and the Tv is set to receive channel 3 , the converter box does all the channel changing and the analog Tv stays on channel 3 all the time. If you have digital Tv's then you do not need a converter box. . I can go into the smallest detail , however it will be very helpful if you can figure out at least some of this your self.
