TV Antennas and Reception
Here is a Truth , reception of television stations that have minus -10 NM(dB) numbers and lower may not be received , if the station is received fine , if not fine. Tv stations that are in the gray part of the listing require ever increasing measures to receive. A person can spend several hundred dollars and still not get the stations. The Tv stations that are in the gray are in the gray for a reason.
