Old 22-Feb-2011, 8:12 PM   #39
Tower Guy
Originally Posted by olimazi View Post
I know the correct way to ground is via ground rod/block/wire outside - but can I get away with using the ground block just inside my basement (close to the entry point) for my antenna?
Probably.
It really depends on the length of the ground wire from the ground block to your house ground. If the CATV installer did it right, you'll be safe and legal, but not all CATV installs are done properly.
