Old 22-Feb-2011, 6:44 PM   #38
If the only risk was voltage buildup between the center conductor and shield of the coax, that would be a good option.
Back to your question of
... can I get away with using the ground block just inside my basement (close to the entry point) for my antenna?
Some people get away with a lot worse... All I can do is recommend doing it right. The link I posted is a bit to wade through but it does include some links to generic drawings and my somewhat biased opinions on the subject.
