Old 22-Feb-2011, 6:24 PM   #7
Tower Guy
Originally Posted by RoCo2011 View Post
Can someone explain ???
My current antenna (A DB8 Multidirectional from Antenna's Direct, is roof mounted apx 30' high and pointed SSE (160 degrees) to pick up the other majors (NBC CBS ABC) all of which work just fine.
A DB8 is not multi-directional. The statement on the web site is implausible: "This DB8 is the ideal antenna for use in locations that can pull long range signals from various directions and offers an attractive alternative to using a directional antenna mounted on a rotator."
According to the posted TVfool report, FOX is hopeless, but because you get it sometimes it should work much better if you add a rotor and a HDP-269 preamp.
You'd probably get PBS from WCBB if you added a real VHF antenna.
