Old 22-Feb-2011, 3:39 PM   #35
olimazi
Question Getting there....
I purchased a Winegard 7698P antenna with Winegard AP-8700 pre amp along w/ 100' of rg-6 coax.
My plan is to eave mount the antenna w/ 5' mast, run the coax loose and connect to tv to see if I get a signal - if everything is good, I do a more permanent installation.
My question is on grounding - there is a unused comcast coax wire entering my foundation, which is connected to a block and is grounded to the water pipe coming out of my well.
I know the correct way to ground is via ground rod/block/wire outside - but can I get away with using the ground block just inside my basement (close to the entry point) for my antenna?
I will pull out the cable company coax, run my new antenna coax through, connect to the block, the run another coax wire to my tv.
John
olimazi is offline   Reply With Quote
