Old 22-Feb-2011, 4:02 AM   #6
mtownsend
In the latest update, all "operational" and "temporary operational" records from the Industry Canada database have been merged into the "current" data for our online tools.
All "authorized" and "license approved" records have been merged into the "pending" database.
So now some cleanup is needed. Any feedback on the following would be appreciated:
  • Which AU and AP records are already on the air (can be moved to "current" database)?
  • Are there any OP or TO records that are not really on the air (can be moved from "current" to "pending", or deleted as appropriate)?
  • Which active transmitters will go off the air after the transition (on or around Aug 31)? If we get these identified, they can be removed from the "pending" database to give that list a more accurate post-transition representation (i.e. take care of channel re-assignments/flash-cuts, remove analog transmitters that will be gone, etc.).
