Okay I will try the TV Antenna first. Do I need the pre-amp?
The antenna wire will run 35' to a home run wire panel where it can be sent to any of the 10 outlets. I will install amp/spliiter if needed.
If I instead mount the antenna on my barn it will be a. lower and b. 240' from the panel. To do this what will I need?
Do I need to do anything for the signal to the FM Reciever?
Thanks.
