Old 22-Feb-2011, 3:00 AM   #6
John Candle
TV Antennas and Reception
The Tv antenna will be pointed at about 149 degree magnetic compass. Like I say , the Tv antenna will receive strong local FM radio stations , try the Tv antenna for FM reception first. If you decide to install a FM antenna , Do Not snuggle the Tv antenna and the FM antenna together like they just got married. Mount the two antennas a few feet apart like they have been married for awhile. If the antennas are mounted on the same mast then the FM antenna will go toward the top of the mast and the Tv antenna will be down lower. . Three questions , How many Tv's will be connected?? . How many Tv outlets the house has?? . Is the Tv coax wiring pulled to one location , a separate coax from the one location goes out to each Tv out let ??
