Originally Posted by wetzel402
It was very strange to say the least but now that I have a different coax identified as the living room and hooked up it works great.
Would you happen to know if I can run cable internet and OTA TV on the same coax John? We receive only cable internet, no TV signal. If it is possible how would I go about it?
Thanks!
Cable TV is a closed system, meaning it must not radiate any signal into the air and it must not allow any over-the-air signals in. Aircraft navigation and communication signals will be interfered with if the 'closed' nature of the cable system is compromised. So, do not mix OTA distribution with any part of the cable TV network.
