Old 21-Feb-2011, 7:26 PM   #2
The Clear Stream 2 is a high quality antenna. However, it is only designed to receive UHF channels, (14 and up).
This is easy to fix though. Add an antenna designed to receive the VHF channels (2 - 13). The Antennacraft CS600 would be a good choice.
The signals from each antenna would be combined using an inexpensive UVSJ
Both antennas can mount on the same mast if there is room (there should be about 6 feet between the two antennas, more is better). You can also mount on separate masts if you like. Aiming is not going to be extremely critical, both antennas are going to allow some 'fudge factor'. Ideally, both antennas would be aimed east. How to aim an antenna
