Old 21-Feb-2011, 5:47 PM   #1
ledtvlady
need help getting wpvi in
Please forgive me but I am not technically savvy with this so I will try my best to explain what is going on hoping someone can give me some insight. My father-in-law used to be able to receive WPVI shortly after the digital conversion but then after a few months it no longer came in. From the initial research I have done this is a common complaint in our area. Supposedly WPVI comes across under a low VHF signal? Not sure if that is right or what that could mean. He uses a Zenith DTV converter model # DTT900 on his TV to gain the digital channels. He just purchased an Antennas direct clearstream 2 which he has set up on the roof. He has positioned this antenna in a verity of ways and has rescanned every time. I am thinking he will need to adjust the antenna to a certain compass pointing to get this station but is this the right antenna or is there something relatively inexpensive he could use to help pick up the signal.
Here is the TV signal analysis link from TV Fool. http://www.tvfool.com/?option=com_wr...8e449746b4fbd9
Thank you so much!
ledtvlady is offline   Reply With Quote
