Old 26-Feb-2010, 5:33 PM   #1
brado
need better vhf antenna
Here I am:
http://www.tvfool.com/?option=com_wr...b7c842cb038d1e
Currently I have rabbit ears & a loop, RCA ANT200B (& an ANT525 w/ a broken ear). There is a big hill is blocking the main antenna cluster. I can a few channels such as 18 (krma) since they're on a different hill. Occasionally I can get 7 &9. If I could upgrade my rabbit ears and get 7 & 9 I'd probably be happy. Would something like the winegard ss300 be better? It's only 25.75 in wide, is that wide enuf for VHF? Or maybe the Philips MANT950 or RCA ANT806. Also wondering about the winegard gs100, maybe that is flat enuf that it will lay on the mantle below the TV and be unobtusive, but I can't find a good picture or dimensional drawing.
I could pull a coax up into the attic and install the antenna there also. If I'm going to go to that much trouble I'd want to get some of the other channels down to about 30 db NM, at the same azimuth.
Thanks
brado is offline   Reply With Quote
