Old 21-Feb-2011, 3:18 PM   #14
wetzel402
Over the weekend I was prepared to run my new coax. I decided before hand that I wanted to mark all cables for location first. I moved my TV to each wall jack and would connect cables until I found the right one and label it. Interestingly enough I found that the one I thought was for my living room was not correct. I found it using the 9 volt battery and multi meter trick but obviously that did not work very well.....the cable may have been too long and had too much voltage drop.
Now that I have found the correct cables everything works great! I had to use my amplifier to keep some channels coming in clear but nonetheless works great!
Thanks so much for the help!
I also tried combining my cable internet signal and TV into one coax because I have a TV and modem in the same spot but this didn't work. Any products out there that can filter these frequencies or are both signals the same frequency?
wetzel402 is offline   Reply With Quote
