Old 21-Feb-2011, 2:08 AM   #2
mtownsend
Can you post a link to your TV Fool report?
It just seems unlikely that you'd pick up a VHF channel (WTRF is on channel 7) with a Channel Master 4228 (a UHF-only antenna) from 88 miles away.
It may be possible that you are picking up a signal from a repeater that is closer to you or on a UHF channel. The signal might be using virtual channel mapping to show up as channel 7.1 even though the real broadcast might be on a different channel. If your TV can tell you the real RF channel that you are watching, that might help us identify the transmitter that is giving you this signal.
If there really is a local transmitter on channel 7, then this investigation might help identify which one it is.
