Old 21-Feb-2011, 1:29 AM   #6
Dave Loudin
Originally Posted by kentrx1 View Post
i have tried that as well as a phillips power antenna indoors at the tv. the phillips worked much better than the bow tie, but still can only get about 6 stations.
Which six? Look at your report... note that there are six stations at 245 degrees and six stations at 128 degrees. If you point an antenna at one group, you won't get much else, because the other stations will be in directions that the antenna will not be very sensitive to. I recommended the simplest antenna as it has the widest beamwidth and will receive in two directions, 180 degrees apart.
Here's the situation. If you aim to Greensboro to the SW, then that's all you'll get. Aiming more southward will allow WUNC to pop in. Aiming at Raleigh, you'll need a VHF-capable antenna for channel 11. So, you can either get a Winegard HD7694 or an AntennaCraft HBU-33 with a rotor to swing the antenna between the two markets, or fix either of those towards Raleigh and use what you already have for Greensboro. Run separate coax feeds into an A/B switch that feed you TV.
