TV Antennas and Reception
It looks like the Tv stations you will like to receive are to the south east. I recommend a Winegard HD7697P Tv antenna and a ChannelMaster CM3414 , four way distribution amplifier. The Correct way to do the RG-6 coax wiring is the RG-6 antenna wire goes to the input of the distribution amplifier and each output of the distribution amplifier goes to a Tv. Having multipul spliters will reduce the signal to the point of not being watchable. I recommend NEW RG-6 coax from the antenna to the distribution amplifier.
