TV Antennas and Reception
Yes we all know about the hd stacker and have for a long time. Here is the main point in your situation , the hd stacker has no long reception elements for the reception of VHF Low Band Channels of 2 thru 6. . I never recommend the hd stacker because the VHF High Band channels 7 thru 13 antenna stacked on top of the UHF antenna blocks and limits UHF reception. A length of two conductor wire (a phasing loop) the loop is long because it is a phasing loop , not simply connecting wires that connect the two antennas together , the loop is held in place by plastic supports , the plastic supports will break , the wire will break , Denny's antenna service has CAREFULLY Worded Statements about the hd stacker. I know the truth about the hd stacker and so do others , I never recommend it.
