Old 18-Feb-2011, 3:07 AM   #10
wetzel402
Hello again
I have an update.
I have now tried my TV in the guest bedroom of the house as well as the master bedroom. Both locations worked great. I then removed the wall plate from my living room to inspect the connectors. The wall plate appeared fine but to confirm I used it like a coupler with two coaxes in the master bedroom and everything worked great. I then checked the in wall coax. It had a crimp on end so I removed the old one and installed a new crimp just to be safe and still have the same problems. Does this mean the coax in the wall is bad? If it is ran "loop" style in my living room does the cable need to then make a complete loop (circuit) to function correctly? I am loosing several channels and having reception issues on others. It functioned great in both bedrooms.
wetzel402 is offline   Reply With Quote
