Old 18-Feb-2011, 2:53 AM   #7
Tower Guy
Originally Posted by f308gt4 View Post
OK, here is the revised report (I used 10 ft as antenna height):
FWIW, I have attached it with a 25ft quadshielded cable, which goes into a ground block, and then another 12ft cable which goes through the wall and to the TV.
If there is no building in the way that isn't shown on TVfool I'd suspect a bad connector or balun. Use one of the two rg-6 lines and connect the antenna to the TV with the antenna hand-held or on the window sill. Next try the other RG-6. Look at the connectors. Try another balun.
