Old 24-Feb-2010, 7:15 AM   #4
mtownsend
Thanks for updating your tvfool report.
Well, it still looks like all your signals are VERY strong and all coming from one direction. That's about as good as you could hope for in OTA television! Many people would be jealous of your situation.
Are you having any trouble on any of your VHF stations (WFAA or KFWD)? If not, then your rabbit ears are probably doing their job.
When you connected the rabbit ears, how did you join the signals with the ones coming from the 4-bay antenna? The best way to combine signals from separate VHF and UHF sources is through a diplexor like the UVSJ. This merges the signal from two bands onto a signal coax with minimal loss and it also minimizes cross-interference between the two antenna types. If you are using a regular 2-way splitter/combiner to join the signals, I recommend that you try replacing it with a UVSJ.
Now, in regards to KERA... It's hard to say why you're not getting reliable results on this channel. It's strong and line of sight, so it ought to be easy to receive. However, here are some things to check for:
1) If you haven't already, use a UVSJ to combine your VHF and UHF feeds instead of a standard splitter/combiner.
2) Don't use any amps. Your strongest signals are probably too strong for most amps to handle. If you have any amps in your setup, remove them completely. With signals this strong, amps can make things worse rather than better.
3) What is the spacing between your bowties and the reflector screen? The sweet spot for this kind of antenna is to keep about a 4 to 5 inch gap between the bowties and the screen. The way it's shown in the graphic of your original post, the spacing looks way too small. Each of the whiskers of the bowties should be about 8 inches long. These rough parameters should get you pretty well set up for good UHF performance. If you're not sure about your antenna build, then post some pictures and we can take a look at it.
4) Are you splitting the signal to multiple rooms? If so, make sure you don't have any open unused ports (either open ended cables or open ports on a splitter). All unused ports should be terminated with a 75 ohm terminator (like this). Any paths left open-ended can cause signals to reflect back into the coax, creating signal "echos" within your distribution network that makes the signal harder for receivers to decode.
5) Try turning or relocating your antenna to see if that makes any difference. Some places might be plagued with signal multipath (reflections from surrounding objects, buildings, terrain, etc.). By re-aiming or moving the antenna, you might be able to find a spot that has less multipath getting into your antenna. If this helps clean up the signal, your receivers might then be able to lock on to the channel.
