Old 16-Feb-2026, 12:41 AM   #2
Originally Posted by MnToyGuy View Post
http://www.tvfool.com/?option=com_wr...c08d27e3be16c7
Looking for a good attic mounted antenna. You guys helped at the cabin
Set top antennas work fine on 2nd floor and iffy on 1st. Going to go with attic antenna split between 2-3 sets
Hello, MnToyGuy
The TVFool signal reports are no longer accurate. I suggest using a rabbitears.info report found here:
An estimated report for your location:
https://www.rabbitears.info/searchma...udy_id=2507208
I suggest a GE29884 antenna:
https://www.amazon.com/GE-Outdoor-Su.../dp/B01MYMVPVX
