Old 5-Jul-2024, 12:34 AM   #2
Originally Posted by Esteban View Post
I am trying to help an elderly friend receive OTA channels & save her some money. I have already told her that this would be a challenge ! She has tried several indoor types, that at best, received 1-2 stations. Her house sits very low off the road . The entire West side is covered with tall trees. Many are 50 ft. taller than the peak of her roof ! The East & Northeast are relatively clear of trees, but still in a very low area.
I appreciate any help & suggestions that you may provide . Thanks !
https://www.tvfool.com/?option=com_w...b0fed01eb7d03a
antenna direct https://www.antennasdirect.com/transmitter-locator.html
Hello, Esteban. Thank you for the TVFool report.
TVFool reports are not as accurate as they used to be, so please do a report for her location using a report from rabbitears.info. I use coordinates when requesting a report.
Is her antenna actually 50 ft above ground level?
I did an estimated rabbitears.info report based on the TVFool report with the antenna at 30 ft above ground level:
https://www.rabbitears.info/searchma...udy_id=1390478
What are the callsigns of the stations she is able to receive?
If you can give me her address in a Private Message, I can look at the trees in the signal paths.
