Old 16-Feb-2011, 10:39 PM   #2
TV Antennas and Reception
The Tv transmissions in green are Strong , a Simple Non Amplified indoor antenna will receive them if the house is a wood frame house with wood/wood composite or vinal/plastic siding. . No metal siding and no metal roof. And no buildings that are close by and in the path of the Tv stations to the south/south east. Here are SIMPLE Non Amplified indoor Tv antennas , http://forum.tvfool.com/showthread.php?t=233 . Here is how to aim Tv antennas , http://www.kyes.com/antenna/pointing/pointing.html . . . If you will like to reach out for the Tv stations in yellow in the same direction of south / south east then I recommend a Winegard HD7697P out door antenna , this is a big antenna and will supply signal to 2 maybe 3 Tv's. . How many Tv's will be connected?
