The problem is the amplifier. You have EXTRAORDINARILY strong analog signals that are overloading it. Seriously. All you need for now is a simple loop antenna or single bow-tie antenna, neither should cost more than $5.
To keep abreast of Canada's transition to digital TV broadcasting, and to see what others in your vicinity have done, consult the OTA forum at digitalhome.ca. There will be a thread for your area in the reception results sub-forum.
