Old 6-Jul-2023, 11:02 PM   #16
Originally Posted by Dagwood View Post
I was walking between my barn and house yesterday and just happened to look up. My antenna has moved, by quite a lot. It must have been the wind back in the spring. I've always tightened it as much as I dared but apparently it moved anyway for the first time.
Previously I would tune my TV to Fox, the weakest station, while I was still getting SOME signal (fall//winter/spring). I would turn the volume way up on the TV, open the windows, get on the roof and tweak the antenna around till the sound was steady. Every few years I would have to go up and move it a few inches, but haven't touched it in several years now.
I thought I had it in the sweet spot but I wasn't even close. The antenna is 10 or 12 feet long, and I bet the end has recently moved by around three feet from where I had it.
Knowing that I am south and slightly east of the transmitters, I wouldn't think it would pick up anything at all according to where it's aimed now. But everything's still coming in flawlessly, including Fox, the weakest one.
I will get a couple more clamps from the hardware store one of these days and beef it up. It's the first time in my life I'm watching Fox in the summer! No audio cut-outs or pixelating!
Thanks for the report. Interesting about Fox reception.
Sometimes, in a location like you have, the best signal doesn't always come from the direction you think it should.
I suggest you use an inexpensive Mediasonic HW-130,(or HW-150 like I use) to find the best antenna aim for the best signal quality. Tyler the Antenna Man uses the HW-130 to make antenna comparisons.
https://forum.tvfool.com/showthread....ewpost&t=16815
https://www.youtube.com/watch?v=YDQzvFG3chs
