Old 29-Mar-2023, 11:40 PM   #6
OTAFAN
But when I change the amp I will definitely open that box again and clean it.
You probably already know this, but I think what rabbit73 and JoeAz meant was checking and keeping your connections free of moisture, rust and corrosion. I can't count the number of times over the years when my electronics had problems and it turned out to be a "connection issue." Either something was just a bit loose, dirty or in the case of antenna connections, moisture and corrosion.
A product that has proven itself issue free for me over the years is Coax Seal. When I finish connecting coax to my antennas, I always seal them up with Coax Seal. I've never had a breach or any problems with my reception. And when its time to replace an antenna, I can remove it without much effort; years or even decades after installation. Some folks don't seem to like it and prefer tape or other things, but I'll have to give Coax Seal "thumbs up" all around.
https://www.amazon.com/Fittings-Univ...A%3D%3D&sr=8-3
https://www.rfparts.com/coaxseal.html
https://www.youtube.com/watch?v=s92i2WALXcQ
http://coaxseal.com/products/
Just a tip from a cheer leader for the forum, Dagwood! LOL!!
