Old 27-Nov-2022, 12:40 AM   #8
Tim
Hi tv4jt,
I agree with OTAFAN. I think your best bet is pointing the DB4e at 18 degrees. Probably wouldn't need the preamp.
You should get W31DH-D (WUNF) which would be PBS, PBS Kids, PBS Encore and the NC Channel.
You should also get W23EZ-D (WHNS) which would be Fox, Cozi TV, ION Mystery, Bounce TV, Grit, Circle and Charge!
If you want more programming than that, then satellite is probably going to be your best option.
Anything else would probably be wishful thinking. The Y10713 is not going to do you a lot of good. The closest channel you could try for would be WNTV in Greenville and the report shows it being so weak that I don't think it would happen. And besides, it is just a repeat mostly of the PBS channels.
