Old 7-Nov-2022, 9:32 PM   #3
richardrosa
Originally Posted by jkeldo View Post
This article mentions the use of RF22 as well as other channels on the iighthouse:
https://www.rbr.com/the-nextgen-roll...itol-district/
Edit:
RabbitEars shows the following for the transmitter:
https://www.rabbitears.info/contour....0&site=1&map=Y
As the map indicates, there should NOT be any signal from this transmitter in Marlboro (West side of the Hudson River). Even weirder is that my antenna picks up the signal ONLY when pointed due East!
I WILL say that it is not a particularly strong signal. The signal level is just barely above what the TV needs to decode.
Also, if I look at various web sites, there SHOULD be at least 3 streams. I can only find 2. However, my Sony is LOUSY at identifying what streams are available on a given RF channel. The USB device I used for IDing what is present unfortunately does NOT do ATSC v3 (NexGen)..
Thanx for your help.
Richard Rosa
richardrosa is offline   Reply With Quote
