Hello jamesm113:
You might want to consider the Channel Master Omni Plus 50. Since you've got a very wide reception pattern, this antenna is supposed to be able to pick up 360 degrees. You can read other user comments about CM Omni on their website, which might help you decide.
Please give the forum a follow up when you get settled. I'm sure it would be helpful to others.
Thanks for posting and all the best.....
