Hi Again:
Looking over a couple of your previous threads posted here on the forum, olnick; are you still living in Milford, NH? And is Boston your market where you receive your TV stations from? If you could post a current report from rabbitears.info or TVFool, that would be helpful.
Also, what is your present antenna set up? And do you still have large trees about 75 feet from your location, that partially block your view from towers to your home? (You mentioned that in one of your early threads).
As far as loosing channels through the day in Summer, that could be due to the trees with leave growth and/or the inversion layer effecting VHF signals, particularly Low VHF; depending, of course, on signal strength from your towers. Your antenna set up would also come into the equation here as well.
I'm sure other posters or techs could read your past threads to get a better idea of your situation. But current information, I suspect, would help them give you the best advice possible.
Thanks in advance for your replies. Getting your situation cleared up will also help others too.
All the best.....
