Old 25-Aug-2022, 10:36 PM   #3
olnick
Thanks for the prompt reply
I'll be replacing it Sat/Sun as the weather is supposed to be cooler to get up on the roof!
Past History: I have had issues since the install of loosing channels as the day warms up? winter time I get 30-35 channels crystal clear! this is first thing in the morning. As the day heats up at the peak 2-3 PM I'm down to 10-12 with the remaining mostly pixelidated.
Summer time I get 3-4 clear in the AM and maybe 1 good one in the afternoon.
I have tried a number of different Balun's with different results! I'm hoping the CM-3203 will eliminate all the hit/miss on reception.
Yes I changed the RG-6 from the pre-amp to the house connection.
Yes I replaced the pre -amp at the antenna.
Yes I cleaned the connections on the antenna still reads ZERO ohms
Yes I checked the connections on the distribution amp (two sets) if bypassed to just one set the drop out still remains!
I'll up date after replacement with results with full length leads on CM-3203
OlNick
olnick is offline   Reply With Quote
