Old 16-Feb-2011, 3:12 PM   #4
f308gt4
OK, here is the revised report (I used 10 ft as antenna height):
FWIW, I have attached it with a 25ft quadshielded cable, which goes into a ground block, and then another 12ft cable which goes through the wall and to the TV, so I do have some excess cable on the outside. Could that be the issue? Should I trim the 25 ft cable to eliminate the excess?
http://www.tvfool.com/?option=com_wr...7ebbd76dd2d673
When I installed the antenna, I used the exact report, and used a compass to aim the antenna at about 323 degrees. Not sure how accurate I was though, may be off by a couple of degrees (<10).
Thanks!
f308gt4 is offline   Reply With Quote
