Thread: VHF station
Old 10-Jul-2021, 6:53 PM   #2
Originally Posted by ssharnick View Post
My question is do you think if I point the antenna toward the UHF towers I want to receive (WFSB, WVIT...) will the VHF elements pick up the VHF station (WTNH) that I want from the side. The location is below.
Hello, Shawn.
That's difficult to predict. WTNH will be in a null, making it a lot weaker, when the antenna is aimed at WFSB, but it will help that WTNH is much stronger.
You might have some multipath reflections that will interfere with the reception of WTNH when the antenna is not aimed at WTNH.
You will just have to try it.
https://www.rabbitears.info/searchma...tudy_id=242706
If it doesn't work, you will need to use separate UHF and VHF antennas combined with a UVSJ.
File Type: jpg Televes DAT BOSS MIX LR VHF-High Pattern_1.jpg (103.1 KB, 4349 views)
