Old 3-Jun-2021, 1:06 AM   #27
Originally Posted by deeciple View Post
Hi Rabbit73,
I know this is an older thread but I am thinking about moving my antenna up higher to see if I can clear that duct and get better reception. I am noticing that whenever the air handler kicks in my reception is affected.
Hello, Ken
That sounds like intermittent electrical interference. The antenna must be near the source.
I have radiant barrier to the left and right (on the slopes of the roof). If I go up higher, do you think that the reception will be worse due to the narrower wall in front of the antenna, with the barrier being on either side?
It's difficult to predict. If there is no metal in front of the antenna to block the signal, it might improve the reception.
