Old 2-Jun-2021, 10:26 PM   #26
deeciple
Thank you for the photo of your antenna in the attic. I see a black pipe or duct in front of the antenna. If it contains metal or foil it might block the incoming signals.
Hi Rabbit73,
I know this is an older thread but I am thinking about moving my antenna up higher to see if I can clear that duct and get better reception. I am noticing that whenever the air handler kicks in my reception is affected.
I have radiant barrier to the left and right (on the slopes of the roof). If I go up higher, do you think that the reception will be worse due to the narrower wall in front of the antenna, with the barrier being on either side?
Thanks,
Ken
deeciple is offline   Reply With Quote
