Old 31-May-2021, 11:57 PM   #8
Originally Posted by Caveman007 View Post
Thanks a lot for the help
I will look into that antenna. :
P.S. do I need the reflector that comes with it? And what's the chances of picking up channel 10 London when pointed towards the Detroit area. sorry for being a pain.
Hello, Caveman007
The C2V comes with a reflector. You will need to remove it to make the antenna bi-directional. The newer C2MAX doesn't come with a reflector, but one is available as an accessory.
Receiving channel 10 from London will be difficult. You might need a separate VHF-High antenna for it if that channel is important.
The TVFool reports are not as accurate as they used to be; the database is out of date. I did a rabbitears.info signal report based on an estimate of your location:
https://www.rabbitears.info/searchma...tudy_id=270196
You can do your own report here (I use coordinates from Google maps):
You are outside the area of coverage for CFPL:
and there is terrain blocking the direct signal:
