Hi deeciple:
I have one of those and have used it in the past with expected results, from min to max. I can't remember what specs or numbers I was receiving, though.
I'm not using it currently so I can't report any present feedback. But since you did stabilize the signal to your receiver with a 6db attenuator as mentioned in your prior post, this might give you a bit more flexibility. Give it a try.
Let the forum know what results you get. I'm sure it would be helpful for some.
Thanks and all the best.....
